Activity Forums Adobe After Effects Steam for a Coffee Cup
  • Steam for a Coffee Cup
    Posted by Ross Kidd on September 15, 2008 at 4:16 pm
    I need to create steam coming off a coffee cup. Can someone give me some help achieving this.
    I tried animating with frames but I did not get the organic effect required and thing this is exactly the kind of thing AE is good at.
    Ross
    David Bogie replied 18 years ago 4 Members · 3 Replies
  • Tl Westgate
    September 15, 2008 at 4:40 pm
    Have you tried CC Particle World?
    — TL
  • Darby Edelen
    September 15, 2008 at 8:05 pm
    Either a particle system or Fractal Noise might work well for this.
    If you’re going to try Fractal Noise then I’d recommend using the ‘Strings’ noise type with a fairly low complexity (2 or 3), a reduced horizontal scale and an increased vertical scale.
    Darby Edelen
    NVIDIA
    Santa Clara, CA
  • David Bogie
    September 17, 2008 at 7:40 pm
    Foam has a credible smoke preset.
    Carefully examine some real steam on some real coffee. It’s easy to overdo these effects.
    Better yet, shoot some real steam heavily backlit against black and lay it over the footage using Screen
    bogiesan
