Activity › Forums › Panasonic Cameras › Status of Adapter card for P2
  • Status of Adapter card for P2
    Posted by Steve on January 28, 2007 at 9:15 pm
    Does any one know what the status of the card adapter is so I can use the MacPro to transfer P2 cards to a hard drive? https://www.duel-systems.com/products/adapters.aspx
    Heading out in a few weeks for a shoot overseas as a one man band and I need a effecient work flow to get the data off the cards without having to bring a PC with me as well. Would be great if someone had a dual card transfer device without using the camera. Would like to start the transfer of the 2 cards, insert 2 new cards as the transfer is being done so I could have the option to continue to shoot as the data is being passed from the first set of cards to a drive. I will have to edit on location as well and do NOT want the data transfer to be a baby sitting job, as I insert card # 2 as soon as card # 1 is completed.
    Not sure if my needs will be better served with Sony Z1U and a deck to transfer footage to a hard drive.
    Has any one shot in 24p NTSC under 50hz conditions in Pal land.
    Any ideas?
    Steve
    Jeff Carson replied 19 years, 8 months ago 4 Members · 3 Replies
  • Jeremy Garchow
    January 29, 2007 at 2:08 am
    As a one man band the P2 store is awesome. Rent one or two and see how you get by.
    Jeremy
  • D. scott Dobbie
    January 29, 2007 at 5:52 am
    “Would like to start the transfer of the 2 cards…”
    Remember that the cards are hot-swappable. When I’ve loaded one up, I just pop it into my G4 while I’m filling the 2nd one (I realize you don’t have slot in your MacBook Pro – I mention this so you don’t feel the need to get 4 cards).
    -Scott
  • Jeff Carson
    January 29, 2007 at 5:02 pm
    As far as shooting under 50khz lighting at 24 p, you very likely will get light flicker issues. I once shot with a 16mm film camera setup to 25fps (inadvertently) and the 60khz hmi lighting (US) flickered enough to be an issue.
