Activity › Forums › VEGAS Pro › Station filetype specs for HD spots
  • Station filetype specs for HD spots
    Posted by Kelly Griffin on March 9, 2011 at 12:11 am
    I’ve got kind of a double-whammy for a deliverable:
    I’ve got spots shot and built in 1080-24p, and stations here will only take 1080-60i (I didn’t know about the 24p until after the fact), with these specs:
    — DVCPRO HD codec
    — MPEG2 4:2:2Profile@Main Level, upper field first
    — MOV H264@60Hz
    My questions:
    (1) In my 1080-24p project am I okay to just render MOVs at 29.97, or do I need to do something like render them inside the 24p project as is, start a new project with 1080-60i settings and do it there?
    (2) How do I accomodate the DVCPRO and MPEG2 specs above? Is “DVCPRO HD” the same thing as “DV/DVCPRO NTSC” in the “Video format” dropdown list for MOV compression? Where can I find the MPEG2 one?
    THANKS!
    John Rofrano replied 15 years, 6 months ago 2 Members · 3 Replies
  • John Rofrano
    March 9, 2011 at 1:26 am
    [Kelly Griffin] “(1) In my 1080-24p project am I okay to just render MOVs at 29.97, or do I need to do something like render them inside the 24p project as is, start a new project with 1080-60i settings and do it there?”
    You can simply render your 24p project as 29.970 and Vegas will add the pulldown necessary to make it compliant. You don’t have to do anything special.
    [Kelly Griffin] “(2) How do I accomodate the DVCPRO and MPEG2 specs above? Is “DVCPRO HD” the same thing as “DV/DVCPRO NTSC” in the “Video format” dropdown list for MOV compression? Where can I find the MPEG2 one?”
    DVCPRO HD, MPEG2, and AVC/H.264 are three different codecs. You can only use one of them.
    Vegas doesn’t come with a DVCPRO HD codec (no it’s not the same as DV/DVCPRO NTSC which is SD). It is a format introduced by Panasonic and is a direct competitor to HDCAM developed by Sony. You would have to purchase RayLight to get that codec (it’s $150).
    Vegas can’t render to H264 in a QuickTime MOV container. You would have to buy QuickTime Pro and render twice (once to get out of Vegas and once in QuickTime Pro).
    That leaves MPEG2 which Vegas can render but there’s a problem with building a proper template. You said they want “MPEG2 4:2:2Profile@Main Level, upper field first”. The MainConcept MPEG2 encoder that Vegas uses will do 4:2:2 Profile@High Level or 4:2:0 Profile@Main Level but not 4:2:2 Profile@Main. Also Vegas limits 4:2:2 encoding to 15Mbps and I’m sure you would want to use something higher like 25Mbps or even 50Mpbs. (they didn’t specify the bit-rate??? what bit-rate do they want?)
    Vegas can produce XDCAM in an MXF container using the HD422 1920×1080-60i 50 Mbps template. This is a great format for delivering HD footage. Ask them if they can ingest Sony XDCAM MXF files?
    Otherwise ask them if they will accept MPEG2 4:2:0 Profile@Main Level which is the same quality used on Blu-ray discs.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Kelly Griffin
    March 9, 2011 at 1:40 am
    THANKS JOHN. I hate this part.
  • John Rofrano
    March 9, 2011 at 1:44 am
    [Kelly Griffin] “I hate this part.”
    Me too but look on the bright side… at least they are willing to accept a file. If you were dealing with a network like PBS, they only accept HDCAM tape so you need to spend some serious bucks to a post house to create the tape for you. You have it easy! 😉
    ~jr
