Activity Forums DaVinci Resolve Static Noise clips?
  • Static Noise clips?
    Posted by Anna Fisher on March 7, 2013 at 8:54 pm
    Hi there,
    I exported my xml from premiere cs6 into resolve lite. Did my color grading and looked through it and it was fine.
    Today I open it up and all the clips are just static noise. I clicked a clip in the media pool and opened up the source file in the finder, which played fine. There is no relinking or reconnecting problem.
    I have no idea what is going on – any words of wisdom out there?
    Anna
    Anna Fisher replied 13 years, 6 months ago 2 Members · 2 Replies
  • Peter Chamberlain
    March 8, 2013 at 5:03 am
    Hi, you don’t mention the system details or OS. Is the project and clips fine if you open the project again?
    There is a known GPU/OS issue in the sleep process that is out of the Resolve app control and it might be this you are seeing. We recommend you turn off the energy saver settings and before you complete your session, save the project and exit. Then open the project cleanly when you next come back to the machine.
    If this is not the issue you will need to offer some more detail.
    Peter
  • Anna Fisher
    March 10, 2013 at 5:11 pm
    yes that was the problem. I just re-opened it and it was fine. I didn’t know it did that and was pretty worried!
    Thank you!
