Activity Forums Adobe After Effects Static, 3d and interlacing effects
  • Static, 3d and interlacing effects
    Posted by Gordon Spurs on November 12, 2010 at 1:58 pm
    Hello Guys!
    I’m hoping to treat some live action, degrade the footage
    so it appears corrupted, interlaced, static and so on (see video below).
    It would be amazing if someone could point me in the direction of some cool tutorials as the deadline is pretty tight.
    https://vimeo.com/12273190
    (it doesn’t have to be strict;y like this, it’s merely an example).
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Chris Wright replied 15 years, 10 months ago 2 Members · 1 Reply
  • Chris Wright
    November 12, 2010 at 6:22 pm
    pick one lol,
    1. there’s scratches, blobs
    https://forums.creativecow.net/readpost/2/989980
    2. leader(you can get that from premiere’s file-new smpte leader.
    3. chromatic aberation effect-shift each color as screen and add optics compensation or aescripts has one.
    4. cc ball action set as screen
    basically a lot of grundge elements set as screen, opacity around 20%
    I didn’t see any interlacing elements but if you want them, you need to double your framerate with timewarp or twixtor, then put into a 1/2 fps comp to force fields into frames again.
    https://technicolorsoftware.hostzi.com/
