Activity Forums Adobe After Effects Expressions Starting point of the Solid mask path is the same as Main Solid.
  • Starting point of the Solid mask path is the same as Main Solid.
    Posted by Ming Hsu on May 31, 2023 at 8:57 am
    I have a two Solid Mask Path,two points like a line.
    And i named Main Solid and 2rd Solid.
    I want to 2rd Solid starting point with the Main Solid only,
    and Finished point i can adjustment.
    I have one way to fix.
    Use the Points follow Path creat 2 Nulls with Main Solid and 2rd Solid.
    it’s can link 2rd start point Null to with Main Solid start point Null.
    But i have more Solid to do ,its makes me a lot of layers.
    How can i write expressions of mask??
    Ming Hsu replied 3 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
