Activity Forums Apple Final Cut Pro Legacy Starting a new project.
  • Starting a new project.
    Posted by Chris Kellam on June 3, 2008 at 7:11 am
    I will post here as well because I am unsure of which forum is best for my question. Can someone let me in on the optimum basic settings for both sequence and capture when setting up and starting a new project on fcp, shot in “24p” and “squeeze” modes on a panasonic 100b. Also why am I getting the following error message when attempting to capture informing me that, in essence, my deck cannot be located through firewire; although my deck camera is on, and properly connected to the computer in VCR mode? Thank you for any help.
    Regards,
    Chris
    Chris Poisson replied 18 years, 3 months ago 2 Members · 1 Reply
  • Chris Poisson
    June 3, 2008 at 2:14 pm
    Chris,
    If you shot 24p and not 24pa then you just set up a regular DV NTSC easy setup. If you want anamorphic then check that box. 24p is used in FCP at 29.97, it adds pulldown.
    Have a wonderful day.
