Activity › Forums › Maxon Cinema 4D › Started my animation before 0 frames what do I do know?
  • Started my animation before 0 frames what do I do know?
    Posted by Jason King2 on April 10, 2007 at 3:29 am
    I was building a fairly complex animation scene, and had everything timed but the camera was moving too fast. So to slow the camera down I started the camera before 0 frames. Thinking about this now it was probably not a good thing to do, is there any easy way to remedy my mistake without having to manually move all my keyframes?
    any help for my blunder is appreciated
    Jason King2 replied 19 years, 5 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    April 10, 2007 at 6:17 pm
    If you’re using r10 you can move the timeline view to the document (Main) level and move the whole animation by clicking on “Document” in the left-hand pane and dragging the red bar under the time slider. In previous versions you can do the same thing, but you’ll have to manually multi-select all tracks first.
  • Jason King2
    April 10, 2007 at 9:36 pm
    Adam,
    Yes I have r10 and this worked quite nicely, so Thanks!
