Activity Forums Panasonic Cameras StarTech Cardbus to ExpressCard Card/P2 Card issues.
  • StarTech Cardbus to ExpressCard Card/P2 Card issues.
    Posted by Gabe Hatfield on March 29, 2009 at 1:35 am
    I’m curious to know if it is possible to use this adapter to read P2 Cards (64GB) on my MacBook Pro, 2.66 Intel Core 2 Duo, 10.5.6. Has anyone tried this and had success?
    According to one review I read online before buying the card, the reviewer had success reading P2 cards using the StarTech card on a Windows machine.
    My system seems to be recognizing the cardbus adapter and the P2 card. I also have no problem reading P2 cards using the Panasonic AJ-PCD35 reader.
    Gabe
    Hatfield Post/Production, Inc.
    819 W. Superior
    Chicago, IL 60622
    312-226-3200
    312-226-3211
    http://www.hatpost.com
    Tom Klein replied 17 years, 5 months ago 4 Members · 3 Replies
  • Bo Skelmose
    March 30, 2009 at 6:44 am
    Hi
    I can only say that I use it on a PC in windows without any troubles.
  • Matthew Romanis
    March 30, 2009 at 9:54 am
    Have you transferred and used any media using this option?
    It seems to have no supporting drivers, which if the P2 cards are natively recognised, might be a good thing.
  • Tom Klein
    March 31, 2009 at 3:33 am
    Hi Gabe,
    You bought this Adapter and it shows in your sys profiler as loaded, so it should work.
    10f7 is Panasonic’s ID,
    insert a P2 card into the adapter and insert it into your lappy then re boot , then go to sys profiler “Contents / PC Cards” and see if the P2 card is shown there, if it is, it’s a goer, if not, use it on a windows box, or as a paper weight, then go back to using your PCD35.
    Cheers
    olinevideo.com.au
