Activity › Forums › Apple Final Cut Pro Legacy › staright vs None/ignore alpha? a couple of questions for you guys…
  • staright vs None/ignore alpha? a couple of questions for you guys…
    Posted by Lisa Rolley on February 10, 2009 at 4:05 pm
    Hello friends
    I just got a QT file that is almost 8gb in file size HD 1920×1080 @ 23.98 and it was not playing down in FCP for some reason so i noticed that the alpha tab had defaulted to straight so i switched it to none/ignore.
    My question/s basically are what if anything do i have to be aware of or concerned about – I believe this was rendered out of AE by an animator but before i deliver this i want to be sure to cover my ass.
    I will be getting some animated supers and I am doing the sfx / music mix myself in fcp…not sure yet how this is being delivered but if for example i need to lay off to Digi what would be the best way for me to convert this 1920×1080 23.98 sequence for NTSC digi layoff – should i have an AE guy convert or re-render or in that I have a blackmagic card can i be do a ltrbx downconvert whilst laying off or is that option out the window in that its not 29.97??
    thanks in advance
    Lisa : )
    Lisa Rolley replied 17 years, 7 months ago 2 Members · 2 Replies
  • David Bogie
    February 10, 2009 at 6:34 pm
    [Lisa Rolley] “I just got a QT file that is almost 8gb in file size HD 1920×1080 @ 23.98 and it was not playing down in FCP for some reason so i noticed that the alpha tab had defaulted to straight so i switched it to none/ignore. “
    The file is probably using the Animation codec. There are almost no FCP configurations that are capable of playing back and processing Animation files in realtime.
    bogiesan
  • Lisa Rolley
    February 10, 2009 at 8:13 pm
    no the codec is actually NONE but thanks anyways…
