Activity › Forums › Adobe Premiere Pro › Stange Export from Premier 5.5
  • Stange Export from Premier 5.5
    Posted by Dorian Weber on October 8, 2011 at 1:27 pm
    I have a 3.5 sec clip… a time lapse, but it is too short.
    So I copy/paste that clip. The action starts after about 2.5 sec only. When I paste the clip, I choose Speed/Duration and select reverse speed. Then I copy the same clip again, trim off the first 2 sec and copy that again with reverse speed.
    It looks very nice.
    In the upper time line I have the title.
    I render the whole clip. Looks very nice when I run it in the timeline.
    I was able to make a 12 sec clip out of it.
    Now….. when I export, I have 12 sec, but the action starts only after 9 sec (in the time line after 3 sec) and then the movement is only 1x. What did I do wrong?
    Tried several options to export, even hi-lite all clips before exporting… always the same.
    Getting nervous, because I am suppose to deliver this clip tonight
    Thank you!
    Dorian
    Dorian Weber replied 14 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
