Activity Forums Avid Media Composer standard defintion 29.97 adrenline sequence to 1080p29.97 nitris project
  • standard defintion 29.97 adrenline sequence to 1080p29.97 nitris project
    Posted by Seb4book on June 7, 2007 at 10:05 pm
    Does anyone know how to get a SD sequence into a HD 1080p29.97 project? Is there a conversion process, or additional software needed?
    Joe Womble replied 19 years, 3 months ago 3 Members · 5 Replies
  • Joe Womble
    June 8, 2007 at 2:14 am
    Avid’s open timeline approach will let you open a 1080 project and let you either capture SD footage or, by opening a bin with the SD sequence, open the SD sequence. You will have to determine how you want to treat the SD footage. Either use the uprez capability or letterbox the image and maybe apply a graphic background, for instance.
    Regards,
    Joe Womble
  • Seb4book
    June 8, 2007 at 3:13 am
    Joe,
    I might be misunderstanding your response. I know you can switch between SD and HD in the “formats” pull down menu.
    But in the Symphony Nitris, you cannot open an interlaced sequence in a progressive project. I know you can fool a 1080p29.97 into digitizing 1080i footage, but the sequence is flagged as intelaced.
    What version of Avid Nitris allows an open HD 1080 project? How do you access it?
    By the way, thank you for your quick response.
    Steve Brown
  • Joe Womble
    June 8, 2007 at 3:19 am
    I’m sorry…I didn’t know it was interlaced in MCA and progressive in Nitris.
    The best I could suggest here in this case would be Michael Phillips’ conversion approach.
    https://www.24p.com/conversion
    Hope this helps.
    Regards,
    Joe Womble
  • Erik Pontius
    June 8, 2007 at 4:17 pm
    dead link?
  • Joe Womble
    June 8, 2007 at 6:36 pm
    My bad. Didn’t copy all of it.
    https://www.24p.com/conversion.htm
    Regards,
    Joe
