Activity › Forums › DaVinci Resolve › Standard Candle R10
Sascha Haber
January 24, 2014 at 2:15 pmI guess if it doesnt get up to speed it means you have not enough power for that flow.
Blur sharpen blur keeps the image half intact so we dont have a blurry mess in the end.I might have saved the project starting in Version 4, please start in Version 1 which should play on all system.
The FPS show up in the upper left cornerA slice of color…
Resolve 10.1.0.021
Colorist / VFX / Aerial footage nerd
https://vimeo.com/saschahaber -
Simon Blackledge
January 24, 2014 at 2:32 pmNo I know where the FPS is. it takes a bit for it to go from 0fps upto a constant 24
It ramps up.. every Resolve I’ve worked on does.
The clips so short.
If I do it on a longer clip it works.
Margus Voll
January 24, 2014 at 2:52 pmHi.
V01 06 blur nodes 24 fps
V02 12 blur nodes 19 fps
V03 24 blur nodes 10 fps
V04 36 blur nodes 07 fps
V05 01 TNR nodes 24 fps
V06 02 TNR nodes 24 fps
V07 03 TNR nodes 11 fps
V08 04 TNR nodes 07 fpsMac Pro 5.1
Processor 2 x 2.9 GHz 6-Core Intel Xeon with 24GB
OSX 10.8.5
Display : Quadro 4000
GPU : 1 x GTX 780 (PC version, no external power)—
Margus
https://iconstudios.eu
https://vimeo.com/iconstudioseu/videosDaVinci 10, OSX 10.8.5
MacPro 5.1 2×2,93 24GB
GUI 4000 / GPU GTX 780
DL 4K
Eizo Color
Scope Box
Full Ligthspace CMS -
Sascha Haber
January 24, 2014 at 3:07 pmIs it just me or does it look like TNR nodes are more CPU than GPU dependent ?
A slice of color…
Resolve 10.1.0.021
Margus Voll
January 24, 2014 at 3:12 pmThan may be the case as my first numbers seem sort of okay.
BM probably could chime in on that.
Margus
DL 4K
Eizo Color
Scope Box
Simon Blackledge
January 24, 2014 at 3:33 pmWhat I mean is when you hit play does it say 24 straight away ?
Margus Voll
January 24, 2014 at 3:40 pmIt means i get ok NR numbers despite my low GPU power in comparison.
Margus
DL 4K
Eizo Color
Scope Box
Clark Bierbaum
January 24, 2014 at 8:44 pmMac Pro 5.1
Processor 2 x 2.66 GHz 6-Core Intel Xeon with 24GB
OSX 10.8.5
Display : EVGA GTX 680 w/ FSP 450 watt booster
GPU : Cyclone PCIe 2-427 Expansion Board w/ 2x EVGA GTX 580 ClassifiedV01 09 blur nodes 24 fps
V02 18 blur nodes 24 fps
V03 30 blur nodes 18 fps
V04 66 blur nodes 09 fps
V07 03 TNR nodes 13 fps
V08 04 TNR nodes 09 fpsGuess I’ll wait to upgrade! $8k saved!
Clark Bierbaum
Color Grading / Post Consultant
GarnetColor.com
Charlotte, NC -
Margus Voll
January 25, 2014 at 8:36 amSeems to work out nice?!
Margus
DL 4K
Eizo Color
Scope Box
Al Arnold
January 29, 2014 at 7:51 pm[Simon Blackledge] “No I know where the FPS is. it takes a bit for it to go from 0fps upto a constant 24
The clips so short.
If I do it on a longer clip it works.”
Use the loop function. 🙂
