Activity › Forums › Apple Final Cut Pro Legacy › Stand Alone Field Audio Recorder for Use in FCP workflow
  • Stand Alone Field Audio Recorder for Use in FCP workflow
    Posted by Rsk3527 on February 1, 2007 at 3:20 pm
    Can anyone recommend a stand alone field audio recorder that could be easily used in a final cut pro work flow. This is for a show where we will be recording a lot of musical performances. Our sound guy uses a mixer so we don’t necessarily need a mulitrack recorder, just a good field recorder that can record at least stereo and be used efficiently in an FCP workflow. Right now our FCP machine does not have any additional video or audio cards, so we have an apple tower with intel chips that is out of the box. So the only inputs on the machine are firewire, usb and the little mini mic input. Are there any DAT machines that have a firewire or USB output?
    Thanks again,
    Rich
    Ron James replied 19 years, 8 months ago 8 Members · 11 Replies
  • 11 Replies
  • Stu Siegal
    February 1, 2007 at 4:13 pm
    I’m thinking of picking up a Marantz PMD 670 for the same use. Seems to be the most popular in this category, been out for a while, well thought of.
    G5 Quad Core, 4.5 MB RAM, Dual Dell 1905FP’s, KRK RP-5’s, DSR-11, FC Studio 5.1.2 OSX 10.4.8
  • Chris Babbitt
    February 1, 2007 at 4:26 pm
    I’d recommend any of the Flash Card recorders that are available from several major manufacturers. I have two Edirol units that I love. They record up to 24-bit Wave files to a Compact Flash card and I rip the files directly to the computer.
  • Misha Aranyshev
    February 1, 2007 at 5:29 pm
    Which is the cheapest one with TC? Fostex FR2?
  • Chris Babbitt
    February 1, 2007 at 5:54 pm
    I don ‘t know that any of them have timecode. Maybe the Sony, which is quite expensive.
  • Daniel5000
    February 1, 2007 at 6:04 pm
    Hello
    Have you looked at the Tascam HD-P2?
    I have yet to use it in conjunction with FCP but it has robust Timecode features, generates a XML file and I have been happy with its performance and features.
    Just a thought
  • Daniel5000
    February 1, 2007 at 6:15 pm
    PS-
    Its has a built in FireWire port for direct connection to your. Alternatively you can get a card reader, eject the Flash media from the Tascam and copy to you Mac via USB.
  • Ron James
    February 1, 2007 at 10:41 pm
    Wow, I just checked out an Edirol unit at B&H and it’s a lot cheaper than I expected!
    Question: does anyone know if there’s a way to use an XLR mic with this (only has 1/8 minijack in, and a built-in mic) without having to lug around a Beachteck type device?
    Here’s the link, if you’re interested:
    https://www.bhphotovideo.com/bnh/controller/home?O=Search&A=details&Q=&sku=421023&is=REG&addedTroughType=search
  • Chris Babbitt
    February 2, 2007 at 1:09 am
    Edirol makes a heaftier (and more expensive) unit with XLR, otherwise, check out Marantz.
  • Will Salley
    February 2, 2007 at 4:18 am
    Sound Devices 7-series. The 702T would work perfectly.
  • Arnie Schlissel
    February 2, 2007 at 5:02 am
    You may want to check out the Deva recorders from Zaxcom: https://www.zaxcom.com/
    You get 8 tracks of audio with timecode. It records to an internal HD & can export to DVD-RAM.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
