Activity Forums Apple Final Cut Pro Legacy stairstepping issues
  • stairstepping issues
    Posted by Nate Tull on August 4, 2008 at 6:12 pm
    I’m not new to FCP. I have checked my render setting and preferences.
    I have brought in a few good quality jpeg images, when I pull them into my sequence and rotate them to 8 degrees the edged get stairstepping but only after I’ve rendered. when the playhead is at an un-rendered area its clean as a whistle. As soon as I render it goes to crap. Thanx in advance for any suggestions.
    N8Pro
    Kevin Monahan replied 18 years, 1 month ago 3 Members · 4 Replies
  • David Bogie
    August 4, 2008 at 7:47 pm
    They probably will look fine on an interlaced display.
    but, yes, FCP’s rotation filter is notoriously awful. You may need a bit of blur or prefer to do this scene in Motion or, better, After Effects.
    bogiesan
  • Nate Tull
    August 4, 2008 at 7:51 pm
    DV/DVCPRO-NYSC
    720×480 NTSC DV (3:2)
    N8Pro
  • Nate Tull
    August 4, 2008 at 8:08 pm
    I have it on an NTSC Monitor. Still, why does it look great in preview window until I Apple’R’ ? Is FCP that crappy that I can’t even rotate a picture a little bit. Its not like there is even movement involved, its sitting still!
    N8Pro
  • Kevin Monahan
    August 5, 2008 at 4:35 pm
    It’s the nature of the DV Codec. Try rendering in 8 bit uncompressed and compare the results.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
