Activity Forums Maxon Cinema 4D Stage Object need access to Camera attributes and coordinates
  • Stage Object need access to Camera attributes and coordinates
    Posted by Percy Nunery on June 27, 2017 at 9:43 am
    Newbie here, have created a Stage Object and have three camera inside…I now need to make adjustments to one of the camera and cannot figure out how to get to the attributes…all coordinates etc are grayed out. Any help would be greatly appreciated.
    Percy Nunery replied 9 years, 2 months ago 2 Members · 2 Replies
  • Jim Scott
    June 27, 2017 at 1:41 pm
    Selecting a camera in the Objects menu should make its attributes available. Alternatively, with the Stage object selected, twirl open the Camera settings and move to a point in your timeline where a particular camera is active and its attributes will be available there. As you move through the timeline each camera’s properties will pop up when that camera becomes active. If you can’t get it working post your project file so we can take a look at it.
  • Percy Nunery
    June 27, 2017 at 4:24 pm
    Thank you, Jim.
    Discovered in the Layers I had the Camera lock. Unlocking it allowed me to do just what you explained.
    Solved!
