Stackwerks doesnt load.
Hi. I just installed stackwerks with no problem in my intel imac. I had some issues with motion crashing but I somehow got over that . Now I try to load the same files and Motion says it is missing the Stackwerks filter.
On the under library/filters inside motion I can see a folder called zaxwerks but it does not contain anything. Under all I cant find stackwerks either.Any suggestion? After installing the file a new folder was created under user/library/ and created a folder called plug-ins which contains some more files and folders.
Any help is appreciated. Thank you very much.
