Activity Forums VEGAS Pro Stacking clips together
  • Stacking clips together
    Posted by Ged Jurga on January 31, 2015 at 3:35 am
    Is there a way to stack clips together which are scattered across the timeline? I have around 18 hours of footage and i went through each clip and cut it, now dragging each clip closer to each other seems very time consuming i was wondering if there is a button(or a script) that i can use to stack them all together side by side?
    Heres a screenshot of a small section which i want to put all together without draggin each of them to each other.
    Any ideas?
    Thanks in advance!
    Ged Jurga replied 11 years, 7 months ago 2 Members · 2 Replies
  • John Rofrano
    January 31, 2015 at 4:38 am
    [Ged Jurga] “is a button(or a script) that i can use to stack them all together side by side? “
    We have a script called VASST Event Tool that can do that and a whole lot more and its only $9.95 USD.
    Just use Close Event Gaps on Selected Track(s). As the name implies it will close all of the gaps between your events.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Ged Jurga
    January 31, 2015 at 8:49 am
    awesome! Thanks John!
