Activity Forums Apple Final Cut Pro Legacy Stabilizing some footage
  • Stabilizing some footage
    Posted by Sean Meehan on February 3, 2009 at 4:22 pm
    Hello all,
    I’m currently working on a student film, and I have a short dolly shot that ended up a bit shaky, so I’d like to stabilize it. I know that FCP has a stabilizer, but whenever I’ve tried it before, it seems to either do nothing or take so absurdly long to analyze a small amount of footage that I end up quitting. Would you recommend doing it in FCP or Motion? I have the whole Studio Suite to work with.
    John Pale replied 17 years, 7 months ago 3 Members · 4 Replies
  • Rafael Amador
    February 3, 2009 at 4:52 pm
    Hi Sean,
    You are right ,the SmoothCam works great but you need to follow some steps to avoid long “analyzing” times.
    You need to put in a sequence the shoots that you want to stabilize. Clean all the areas with too much camera shake.
    Use the Media Manager to copy the clips of the sequence.
    Open the sequence in the new project and apply the SmoothCam.
    This way only the selected footage is analyzed and processed. If you apply directly to the original sequence, all the master clips would be anaalyzed.
    Rafael
    http://www.nagavideo.com
  • John Pale
    February 3, 2009 at 5:13 pm
    The analysis is performed on the entire media file…so even if you are stablizing a 5 second clip from a 1 hour piece of media, it analyzes the whole 1 hour. The workaround suggested in the FCP manual is to export a self contained movie containing only the clip you want to stabilize. Reimport that and run the analysis. It will be much faster. You might also want to make a self contained movie of the stabilized shot, as any alteration of it will cause the analysis to have be done over.
  • Rafael Amador
    February 3, 2009 at 6:41 pm
    [John Pale] “The workaround suggested in the FCP manual is to export a self contained movie containing only the clip you want to stabilize.”
    Hi John,
    This way SmoothCam has to go through the cuts and sometimes gets a bit messy.
    The Media Manager way lets apply the filter just to the media you selected and adjust the filter for each clip.
    Rafael
  • John Pale
    February 3, 2009 at 8:15 pm
    [Rafael Amador] “Hi John,
    Rafael
    Thanks Rafael, I’ll remember that.
