Activity Forums Adobe After Effects stabilizing and perspective
  • stabilizing and perspective
    Posted by Monster Kid on June 22, 2009 at 12:27 am
    Hi
    I have an issue with a shot I am trying to stabilize. I did the usual to get rid of the up and down and left and right motion by using the stabilizer in AE. But now I have an issue with the camera doing a slight tilt, which shows up as distortion in the perspective. I wondered if there was a way to get rid of this as well.
    I tried to use the pin perspective tracking tool, but didn’t really do what I expected. Not sure if I am using it correctly though.
    Seems to me, there should be a way to use something like Liquify, where it creates a grid and applies the image to it, then tracks offsets and animates ‘against’ the image to stabilize localized details.
    Anthony Cairns replied 15 years, 8 months ago 3 Members · 2 Replies
  • David Bogie
    June 22, 2009 at 3:02 pm
    I’m not at my AE machine to check this for you but look for a filter called Optics Compensation. it won’t necessarily correct perspective distortion caused by a tilt but it can help. You are probably going to need to turn the layer into 3D and tip it. This is a very unsatisfactory solution since it requires up-scaling about half of the image. Those pixels will tend to get noisy.
    bogiesan
  • Anthony Cairns
    January 23, 2011 at 4:17 pm
    hi im having the problem that i cant tilt my grid just move it left and right and up and down.is there a shortcut.please help.i have been at it a while now and am getting a little frustrated.thanx
