Stabilize more than one clip at a time?
Posted by Paul Gregory on January 6, 2011 at 3:13 amIs it possible to stabilize more than one clip at a time?
Thanks in advance
Danny Hays replied 15 years, 8 months ago 3 Members · 2 Replies -
Jeremy Rasnic
January 6, 2011 at 3:22 amYes. I am assuming you are using the built in stabilizer in Vegas Pro 10? You can have it to stabilize the entire clip that the event is pulled from (the main clip that is in your project media tab that contains your selected piece on the timeline).
However, I find that it works best on an event by event basis.
If you are wanting to do two or more events from separate clips, then this is a no go currently using the built in stabilizer.
j razz
https://www.jrazzcreations.com
Danny Hays
January 6, 2011 at 3:26 amI don’t think so,
Unless one of the other guys can write a script for that. Anyone??
