Activity › Forums › Apple Final Cut Pro › stabilize feature disappeared with 10.0.1 ! a nightmare!
  • stabilize feature disappeared with 10.0.1 ! a nightmare!
    Posted by Christian Plähn on October 27, 2011 at 12:56 am
    i m working on a documentary, over 20 h of footage inside of two events, one 24p 1080, the other 720p50.
    final cut is version 10.0.1
    after adding hundrets of markers to the footage in event library mainly translation, now i m doing the fine edit
    in the timeline. i have to stabilize all of the clips because i couldnt use a tripod.
    now at all of my clips from one event (the older one, imported and analysed in 10.0) the stabilize option and the
    rolling shutter option are gone! nothing happens even if directly selected in the clip on the timeline (analyse and fix…)
    deleting prefs didnt help, deleting the render files and stabilization analysis files neither helped!
    i m really worried and panicing, this can t be true!
    i ttach two images of what i see in the inspector when i click clips from the two events in the timeline:
    this is the missing stabilize dialog.
    and this is what i get when i drop another clip from another event in the same timeline:
    a catastrophy! i trusted fcpx to work, now i went so far to see such a big and critical bug. hundrets of hours are in
    this and i don t know what to do. 10.0 doesn t recognize my events and projects anymore, and i now urgendtly need
    to stabilize hundrets of clips keeping the markers on them!
    does anyone have simular problems, a solution for the stabilizsazionor how i renew my clips without loosing the markers?
    HELP!PLEASE HELP! ab thanks!
    John Whalen replied 12 years, 3 months ago 10 Members · 22 Replies
  • 22 Replies
  • Jeremy Garchow
    October 27, 2011 at 2:32 am
    What happens if you click the clip in the browser?
    Have you tried making a new Project and copying/pasting your previous Project into it?
  • Mark Dobson
    October 27, 2011 at 7:50 am
    If Jeremys suggestions do not work you could try re-installing FCPX by trashing the version you have got and re downloading from the App store.
    I have found this has fixed similar ‘what the f***’ problems.
    By the way do you have 2 versions of FCPX on you system? You mention that ver10.0 doesn’t recognize your events and projects anymore? I can’t see how this is possible.
    This article runs through various trouble shooting options but it sounds like you have already tried some of these.
    https://www.kenstone.net/fcp_homepage/troubleshooting_fcp_x_taylor.html
    The main thing however is that you still have your Events and projects intact. That’s encouraging.
  • Christian Plähn
    October 27, 2011 at 9:46 am
    thanks for your help!
    unfortunatly i tried it all, and it didn t help.
    am i the only one having this very strange problem? i imported under 10.0 and analysed while
    importing.
    than i did the update ( and learned that even the smallest update while doing a project is a like opening a door to hell )
    and kept on working. till i found this problem.
    in the meanwhile i found out that in all projects made in 10.0 the clips that have been in the timeline before the update can still be stabilized, and have the option. but bringing the same clip in from the event browser to the same timeline now results in the same missing stabilize option.
    i m a bit thankful that my project and events folders are intact, that i m pretty healthy and my family and friends are fine but im really not encouraged with this problem…but you re right, always could be worse 😉
    no i just face to repeat about 2 weeks of fulltime working with hundereds of markes with translations of 20 h of material.
    thanks for you help, and is there somebody out there having the same problem or a new solution?
  • T. Payton
    October 27, 2011 at 3:17 pm
    I feel your pain. But I think it is solvable, as it sounds like something is corrupted. A few things to try:
    1 – If you locate the original clip in the browser and the replace in the timeline does it still not have the stabilization option?
    2 – If #1 didn’t help, export your Event to XML (deselect all clips in the event browser, then click on the event from the Event Library, then File > Export XML.) and then reimport. Don’t worry this won’t effect your original event, it will import a copy. You will loose shot/take and reel numbers (unexplainably they are not supported in FCPXML 1.0) but if that is a big deal to a batch rename to your clip names to include the shot/take and reel. Then try #1 again with the new event and see if that solves it.
    2a – If you are far along with editing you could try exporting and reimporting your project as XML.
    3 – If #1 and #2 don’t work. I would call Apple.
    4 – If the call to Apple doesn’t fix it. Let us know and perhaps someone here would be willing to screen share with you and try to resolve it (I would be more than happy to help you out.)
    One more question. How far along in editing are you? Is your rough cut done, or are you just getting started?
    T. Payton
    OneCreative, Albuquerque
  • Christian Plähn
    October 27, 2011 at 4:24 pm
    thanks, #1 doesn t work, i ll try #2 and #3 now.
    I m not far in the timeline edit but there are hundrets of markers in the event browser,
    which i have put there with a translator by my side, and loosing these and having to
    replace them would be a real pain, and the worst thing is that i m really in a hurry…
    i hope exporting and importing to xml keeps the markers..i ll tell you in a bit.
  • T. Payton
    October 27, 2011 at 4:33 pm
    I already tested it, markers and favorites come in just fine from FCPXML. 😉
    T. Payton
  • Christian Plähn
    October 27, 2011 at 6:11 pm
    thanks, unfortunatly final cut crashes improting my event…:(
    it doesn t crash reimporting other events, i ll try now with smaller pieces..
    must have done something to get really bad apple karma…:)
  • T. Payton
    October 27, 2011 at 6:36 pm
    Humm. Sounds like your footage may be corrupted. However, why don’t you send me the your fcpxml, I’ll take a look at it if you want. Send it to “t” and-then-that-little-at-sign-then onecreative and then a dot and the “net”.
    T. Payton
  • Jim Giberti
    October 27, 2011 at 8:49 pm
    [Timothy Payton] “Humm. Sounds like your footage may be corrupted. However, why don’t you send me the your fcpxml, I’ll take a look at it if you want. Send it to “t” and-then-that-little-at-sign-then onecreative and then a dot an”
    A nice guy and a smart guy.
    I like you already Timothy.
  • T. Payton
    October 27, 2011 at 11:06 pm
    As an update on this issue, we got it resolved. This project began in 10.0.0 and then had some relinking issues and then it updated to 10.0.1, so I suspect the problems were compounded in the update.
    To fix this I got the FCPXML files for the event and I was able to find out there were corrupted clips. Attempting to reimport the XML resulted in a crash for FCP X. So here is what the bad clips looked like in the xml:
    As you can see the id=”r1″ is an declared as undefined, so that seemed the likely problem.
    While here is what a good clip looks like:
    I deleted the bad clips from the XML resaved and then in imported without a problem.
    T. Payton
Page 1 of 3
