Activity › Forums › Apple Final Cut Pro › stabilize feature disappeared with 10.0.1 ! a nightmare!
John Whalen replied 12 years, 3 months ago 10 Members · 22 Replies
Christian Plähn
October 28, 2011 at 12:02 amthat was really brilliant help! well done! the nightmare is over 🙂
Nick Toth
October 28, 2011 at 11:12 amNice work Timothy!
Christian – I would pass this whole thing along to Apple -
Chris Northcross
November 18, 2011 at 11:45 amStumbled upon this post and by God you guys are awesome!
Tim, I’m learning that I really need to learn more about XML. So far its been this vague concept that frequently pops up, but I’m seeing that there’s a lot of power that I’ve yet to harness. What are some resources you’d recommend to help me get started?
“Whether you think you can or can’t, you’re right.”
T. Payton
November 22, 2011 at 5:20 pmBesides just looking at the file. It’s very readable.
Also you can look here:
T. Payton
OneCreative, Albuquerque -
Rossmore Ross
February 18, 2012 at 6:43 pmThis is off topic but you seem to know everything about FCPX. Quick question…I tried to check the Stabilization box and it goes through analyzing the clip, then it just un-checks the Stabilization box and nothing happens…same thing happens when I check rolling shutter. Would you be able to tell why this is happening? I would appreciate it!
Christian Plähn
February 18, 2012 at 7:34 pmhello,
which kind of footage are you using?in my experience fcpx seems to have some trouble stabilizing interlaced footage. if you are using interlaced footage, just try to convert a testclip of your footage into progressive with compressor or so, and then reimport, look that fcpx interprets it right in the inspector as prograssive and then try again. could be that you have to do this step with your footage…good luck
christian -
Rossmore Ross
February 18, 2012 at 8:59 pmThat might be the case….I’m importing from a kodak Zi8 in 1080
Dylan Kidder
January 5, 2013 at 10:04 pmgot it! double click the clip in the time line that you would like to Analyze and Stabilize.. double click again. and again. until you can’t reduce the file any further and then VUALA! its back! the option is back in the inspector.. also, the clip, in the timeline, has a drop down arrow in the top right corner.. you can find the stabilize option from that list as well.
still learning.. but loving the upgrade for sure. big curve. but worth it in the end. I have yet to take the course offered by an instructor friend of mine.. should prove to be promising. contact me for info. he offers on-site training. brilliant man. anyways. hope that helps.
Dylan Kidder
January 5, 2013 at 10:09 pmyou may need to trim the clip back down to the point of interest that you started with.. otherwise you are working with the entire native length of the clip.
