Activity › Forums › Adobe After Effects › Stabalizing a LONG “Dolly” shot, nothing works!
  • Stabalizing a LONG “Dolly” shot, nothing works!
    Posted by John O’riley on April 14, 2013 at 5:53 pm
    Hey all!
    So we shot a short piece the other day. Its one long tracking shot (about 3mins) with the actor walking towards the camera as the camera moves back via shoulder rig and rolling flat bed (improvised dolly).
    All in a big warehouse, with other actors walking in from the sides talking to him.
    There is a slight s-bend at the end to reveal the last actor, and then a drop down.
    SEE ATTACHED IMAGE FOR A CLEARER UNDERSTANDING.
    https://broken-silence.co.uk/tracking.jpg
    Because of these bits and bobs going on, its making any solution to smooth the shot out redundant.
    Warp Stabilization warps/jellos the actors using the default and perspective settings. Position doesn’t seem to do anything.
    Position, scale, rotation seems to work best, but the “scale” part is making the footage jump forwards and back as the actor walks forwards.
    I tried the old school two point tracking in AE also tried Mocha!
    Nothing seems to work.
    Now Im sure there is a way that I just dont know with my average knowledge, or Im just doing something wrong.
    Im not looking for much, the footage itself is pretty smooth, just looking to make it slightly smooth, get rid of those shakes/bumps.
    Either looking for tips to do it myself, or will give a Film/IMDB credit to anyone who can do it themselves. Happy with either or.
    John O’riley replied 13 years, 4 months ago 3 Members · 10 Replies
  • 10 Replies
  • Darby Edelen
    April 14, 2013 at 6:32 pm
    If you can get a decent camera solve then you might be able to use the 3D Camera Tracker or another camera tracking solution. You’ll probably need to roto out all of the actors in order to get the solve accurate.
    Once you have your solved camera make the footage a 3D layer, parent it to the solved camera and place it directly in front of the camera with these transforms: Position [0, 0, Camera Zoom], Orientation [0,0,0] and zero out any other rotation.
    Now duplicate the solved camera and apply a smooth() expression to all of the keyframed properties. Make sure this is the top camera in the composition.
    Last step you’ll probably need to scale the footage layer up slightly so that it doesn’t leave the frame.
    This works pretty well to smooth things out. You may want to play with the optional properties of the smooth() expression to improve the smoothing for your particular shot.
    Darby Edelen
  • John O’riley
    April 14, 2013 at 11:43 pm
    Hey Darby
    Thanks for replying
    Following your advice this is what I did.
    Selected the footage, clicked “Animation – Track Camera”
    Used these Settings
    Fixed Angle of View
    3D Solved
    Solve Method – Auto
    Detailed Analysis
    Once that was done I clicked “Create Camera”
    Changed the footage layer to a 3D layer and Pick Whipped it to the camera
    THIS IS WHERE I GOT A BIT CONFUSED WITH YOUR ADVICE.
    Under Transform for the camera I changed all the position and orientation keys to 0, 0, 0
    Then duplicated the camera and added the smooth() expression to the position, orientation and zoom (under camera options) of the new 3d cam.
    Played the footage back but nothing was done..
    Iv clearly gone wrong somewhere, can you explain more please.
  • Roland R. kahlenberg
    April 15, 2013 at 12:07 am
    Mask out the actors and other extraneous movement so that the Warp Stabilizer is able to solve, strictly, for camera movement. Once you’v e masked out the actors, you can try the Warp Stabilizer and Darby’s 3D Camera Tracker recipe to see which gives you the best result.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE
    April 15, 2013 at 12:10 am
    [John O'Riley] “THIS IS WHERE I GOT A BIT CONFUSED WITH YOUR ADVICE.
    Under Transform for the camera I changed all the position and orientation keys to 0, 0, 0”
    You apply these settings to the tracked footage layer – NOT to the camera. If you applied these settings to the camera then you would be negating the tracked data.
    HTH
    RoRK
  • John O’riley
    April 15, 2013 at 12:15 am
    If I was to mask them out, would I leave it transparent underneath or make a solid and try and match the colour of the walls/floor?
  • John O’riley
    April 15, 2013 at 12:16 am
    Also, I did the 0,0, on the footage layer.
    But once I duplicated the camera, it send the footage crazy! was spinning around and flipping all over the place haha.
    April 15, 2013 at 12:18 am
    [John O'Riley] “If I was to mask them out, would I leave it transparent underneath or make a solid and try and match the colour of the walls/floor?”
    1) Mask out the actors
    2) Precompose the layer – select Move All Attributes
    3) Apply WS and 3D Cam Tracker separately to test for best results
    HTH
    RoRK
  • Darby Edelen
    April 15, 2013 at 12:40 am
    [John O'Riley] “Under Transform for the camera I changed all the position and orientation keys to 0, 0, 0”
    Don’t change any of the camera transforms. Only the footage. Also make sure that the footage is parented to the solved camera and the Position of the footage is:
    X = 0
    Y = 0
    Z = The ‘Zoom’ value of the solved camera
    The 3D footage layer should look exactly as it did when it was 2D until you duplicate the solved camera and apply the smooth() expressions.
    If you’re having trouble and can share the footage I can give it a shot.
    Darby Edelen
  • John O’riley
    April 15, 2013 at 1:05 am
    just tested the masking/WS on small section, seems to work pretty damn well!
    Now just got to mask 3 and a half mins of footage haha. Fun times ahead.
    Thanks guys
    Really appreciate all the help!
    Will let you know how it turns out!
  • John O’riley
    April 29, 2013 at 2:17 pm
    Hey
    Just wanted to say, the extensive masking and WS worked a treat!
    Thanks for all your help guys.
    If you would like to see the finished film, can bee seen here.
    https://www.broken-silence.co.uk
    1st video, called “Conscience”
    thanks again
