Activity Forums Adobe Premiere Pro SRT file not complete in Premiere
  • SRT file not complete in Premiere
    Posted by Angharad Overton on October 7, 2019 at 12:59 pm
    Hello CC people,
    A film was sent to an external company for subtitling. They have sent back .SRT files.
    When I opened it in PP it came out very short, with only 4 of 70 captions showing.
    I tried converting it to a .scc which then reveals the full file info, but apostrophes get converted to special characters. I then tried a Unicode converter which resulted in only 4/70 captions showing (at least it had working apostrophes!)
    I contacted the company and their advice seems to be to reimport the file, but the exact same thing happens each time. Where am I going wrong?
    Thank you for your help!
    Tod Hopkins replied 6 years, 11 months ago 3 Members · 3 Replies
  • Eric Santiago
    October 7, 2019 at 1:43 pm
    Do you have another NLE to test this on?
  • Angharad Overton
    October 7, 2019 at 2:07 pm
    Hey Eric,
    Thank you for replying. I have found a fix.
    There is a reason it cut off at 4/70 specifically.
    To fix this issue you need to open the .srt file in a text editor. Between each line of code there should be one line break only (see below).
    1
    00:00:08,440 –> 00:00:11,000
    And then we went through
    a funny little door somewhere
    2
    00:00:11,080 –> 00:00:14,040
    which nobody seemed
    to know about at the time.
    There were two line breaks between several lines of text, which seemed to make PP freak out! (example below…)
    1
    2
    which nobody seemed
    Simply ensure there is one line break between each caption and it will fix the problem. Then reimport and enjoy!
    Best wishes,
    A
  • Tod Hopkins
    October 9, 2019 at 12:19 pm
    Note that two blank lines will stop the import even if one of the blank lines is logically part of two line captions. That is, if the second line in a two line caption is blank, acting as a visual placeholder for line 2.
    1
    And we went through the door
    2
    which nobody seemed
    Some caption tools will do this routinely.
    Cheers,
    tod
    Tod Hopkins
    Hillmann & Carr Inc.
    Washington, DC
