Activity Forums Apple Final Cut Pro Legacy Squashed when I export in Anamorphic
  • Squashed when I export in Anamorphic
    Posted by Beverley Callow on April 23, 2009 at 5:51 pm
    Another probably simple question re anamorphic – I have all my project settings, sequence settings marked anamorphic – why doesn’t it export as anamorphic? Instead I am getting a squashed movie?
    Chris Poisson replied 17 years, 5 months ago 3 Members · 2 Replies
  • Bret Williams
    April 23, 2009 at 6:00 pm
    Anamorphic is squashed (or squished really). If you want it to view as 16:9, then you don’t want to export it as anamorphic. Export it as a 16:9 ratio size. 640×360 for example would be a large web 16:9 movie.
  • Chris Poisson
    April 24, 2009 at 3:20 pm
    Brverly,
    The squished movie is normal. For it to look normal when you export it, you’d have to use QuickTime conversion, and set the size to 853×480. Also, I think you can set QuickTime player to display the squished movie at 16×9.
    The squished movie, when put into DVDSP will stretch itself out when you set the track to 16×9. Also, Compressor will do this too, but it will make a file that is 720×404, so it’s a toss up as to which option you go with.
    Here’s a great article.
    https://www.kenstone.net/fcp_homepage/understanding_16_9.html
    Have a wonderful day.
