Activity Forums Adobe Premiere Pro Squashed output to 16:9 broadcast monitor from AJA Kona 3/CS6
  • Squashed output to 16:9 broadcast monitor from AJA Kona 3/CS6
    Posted by Michael Lansdell on September 3, 2012 at 2:58 pm
    I’m testing Premiere CS6 as a possible replacement for FCP for the company I work at, and am struggling a bit with my monitoring of both video and audio.
    The major problem is the video, for whatever reason it’s displaying squashed on my broadcast monitor. I’m using a Kona 3, most recent drivers and Adobe plugins and am going to a 16:9 Sony CRT broadcast monitor, from an SD anamorphic sequence. It looks as if the footage is being squashed as if Premiere doesn’t recognise that the broadcast monitor is 16:9. In After Effects there is a button to fix this, but I can’t find an equivalent in Premiere. Any suggestions? It’s not really useable as is!
    The second problem is – and I suspect this is something I’m overlooking in the setup – but I only get playback of my first 4 audio channels! Not crucial this one, but annoying…
    Any suggestions much appreciated, many thanks!
    Tero Ahlfors replied 14 years ago 2 Members · 1 Reply
  • Tero Ahlfors
    September 4, 2012 at 12:01 pm
    [Michael Lansdell] “but I only get playback of my first 4 audio channels”
    Have you checked out the audio routing/preferences in Premiere?
