Activity Forums Adobe After Effects Square Pixel
  • Square Pixel
    Posted by Kaiserstrasse on April 3, 2007 at 5:04 pm
    Hello all – I’ve recently shot some footage on the Sony HDR FX-1. Looks fine, loaded it into a FCP timeline with the HDV easy setup no problem. When I import this same clip into After Effects 7 I need to have the Square Pixel box checked to get
    the proper aspect ratio on the footage – why?
    Cheers!
    KBag
    Iancorey replied 19 years, 5 months ago 2 Members · 4 Replies
  • Kaiserstrasse
    April 3, 2007 at 5:32 pm
    Dave – thanks for the quick reply. Actually, I knew the camera was 1440×1080, I just found it odd that when I dragged the clip into my AE timeline to make the composition I had to check that box to get it to look right.
    KB
  • Iancorey
    April 3, 2007 at 5:51 pm
    Your footage looks skinny, right?
    It’s Cmd+F should tell you that it’s interpreted as HDV pixasp, right?
    If you enable the pixel aspect correction button* it looks normal (with some preview scaling artifacts), right?
    *comp window, lower right, rectangle with horizontal arrows.
  • Kaiserstrasse
    April 3, 2007 at 6:19 pm
    Ian – Yes, exactly! There are some scaling artifacts, even at full resolution. Thanks for your help.
    KB
  • Iancorey
    April 3, 2007 at 9:01 pm
    High five!
    The scaling artifacts are just from the preview. I’m sure in this day and age of imaging they’re less a side effect and more a reminder that you’re working in pixasp corrected mode.
