Activity Forums Adobe After Effects Expressions [Square Brackets] to change font style and size? IS IT POSSIBLE???
  • [Square Brackets] to change font style and size? IS IT POSSIBLE???
    Posted by Jake Waksman on August 2, 2023 at 1:24 pm
    I am currently trying to find an expression that will allow me to change the font style and font size using square brackets. We have a platform that works as a bridge between a user and After Effects, so any text input is being completed through the API so the manual adjustment of specific characters or words is not available.
    I have the above expression for changing a colour but cannot seem to find one to change both the font style and font size. Please see the colour expression below. This makes sense because I can then choose RGB FILL as an additional property to instruct AE to change the properties of text within square brackets.
    SOURCE TEXT EXPRESSION:
    str = text.sourceText;res1 = str.split(“[“).join(“\u200b”);res2 = res1.split(“]”).join(“\u200b”);
    FILL RGB ANIMATOR EXPRESSION:
    Start Expression:
    txt = text.sourceText;zws = “\u200b”;
    function getPosition(string, subString, index) { return string.split(subString, index).join(subString).length;}
    val = getPosition(txt, ‘\u200b’, 1)
    Stop Expression:
    val = getPosition(txt, ‘\u200b’, 2)
    Dan Ebberts replied 3 years, 1 month ago 2 Members · 1 Reply
  • Dan Ebberts
    August 2, 2023 at 1:59 pm
    Unfortunately, there’s no way to have multiple font styles in a single text layer once an expression has been applied to the source text.
