Activity › Forums › Maxon Cinema 4D › Sprinkles on a donut?
  • Sprinkles on a donut?
    Posted by Kelly Johnson on October 2, 2007 at 2:47 am
    I’ve been using Instances of a capsule, tried an Array, Symmetry etc… I even tried using a particle generator and used the capsules as the particle….
    But, there has to be a better way to add a random amount and placing of an object (capsule)…isn’t there?
    I’m making a donut with chocolate icing and sprinkles and have the rest fairly ok right now but I’m trying to find a more efficient way to add sprinkles…besides an image map.
    Any ideas/pointers?
    Brian Jones replied 19 years ago 2 Members · 2 Replies
  • Kelly Johnson
    October 3, 2007 at 3:26 am
    Should anyone run across something similar, I found a fairly good solution.
    I used the Place On Points2 plugin. I specified the icing (top half of the modified torus I used for the body) and then used a small capsule for the object.
    Using polygons instead of points for placement helped.
  • Brian Jones
    October 3, 2007 at 3:31 am
    MoGraph Cloner object in surface mode
    -Doughnut
    – Cloner Object
    – Sprinkle
    –other sprinkle shapes
    Cloner Object – Object tab (leaving out a bunch of info but these two are the important bits)
    Mode – Object
    Mode – Surface
    Seed and Count to control sprinkles, Selection to limit to poly selection if desired.
