Activity Forums Adobe After Effects spotlight creating moire
  • spotlight creating moire
    Posted by Kiyash Monsef on February 26, 2012 at 6:22 am
    I have a graphic that’s composed almost entirely of solid-colored vector shapes. There are no intricate patterns with the exception of a single gradient generated in After Effects. However, when I add a spotlight layer to the mix, and set my layers to cast shadows, I get this very pronounced moire wave across everything. I thought this might have something to do with the position of the light, so I experimented with moving it and changing the angle, but that doesn’t seem to affect the moire. When I turn off the light, the moire goes away, but I really want to keep the effect of the light, as it’s the only thing that communicates the depth in the scene.
    Here’s an example:
    There’s a camera involved as well, but turning it off doesn’t seem to affect the moire.
    I’m using CS4 on a Mac Quad Intel. Never seen this before. Any ideas as to what’s going on and how I can fix it? Thank you in advance Cow forums!
    Kiyash
    Roland R. kahlenberg replied 14 years, 6 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    February 26, 2012 at 9:10 pm
    There have been lots of identical posts on the same issue. Increasing Shadow Map helps (Comp Settings DIalog – Advanced Tab) as well as using a Point Light. Moving affected layers further apart in z-space is another possible solution.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
