Activity Forums VEGAS Pro Splitting in Sony Vegas 8
  • Splitting in Sony Vegas 8
    Posted by Martin Cleaver on February 17, 2008 at 9:43 pm
    I an a newby to Vegas and note it doesn’t work the way I expect, To be honest I have no idea how to split an video on the timeline (to eg. chop out a bit. I am used to a right click and “split” twice, then remove the piece in between. Sony Vegas doesn’t do this. SO what do I do to edit on the timeline? Probably something glaringly obvious… once you know! 🙂
    Martin
    Edward Troxel replied 18 years, 6 months ago 5 Members · 4 Replies
  • Don Bloom
    February 18, 2008 at 3:04 am
    Place the cursor where you want to ‘split’ the clip. Press “S” Done!
    Don
  • Rick Mac
    February 18, 2008 at 3:08 am
    [Martin Cleaver] “I have no idea how to split an video on the timeline (to eg. chop out a bit.”
    Place the cursor on the event where you want the split and hit the S Key. This will split the event. If you have the “Ignore Event group” button active your audio will be split and not the video, if it is not active both audio and video wil be split. You can place your cursor at the edge of any event and click and drag the event to trim it. Once again the event grouping button will come into play.
    Regards, Rick.
    Rick Mac
    Director of Audio Production
    TCT Network – Directv 377
  • Jerry Waters
    February 19, 2008 at 12:23 am
    You can also drag a region above, hit the s and it will cut the region, delete that but this is only usually useful when you want to recut where two clips join and the exact frame position isn’t so important.
    JerryW
  • Edward Troxel
    February 19, 2008 at 3:28 am
    [Jerry Waters] “and the exact frame position isn’t so important”
    Why this statement? You can get exact frames when creating a region very easily.
    Edward Troxel
    JETDV Scripts
