Activity Forums VEGAS Pro splitting audio l/r
  • splitting audio l/r
    Posted by Gilles Gagnon on March 20, 2012 at 8:08 pm
    I want my audio stereo channel to be split into 2 audio tracks in my project.
    Is the simplest thing to do: copy the audio track and do a “channels-leftonly” and “channels-rightonly” respetively?
    G
    Gilles
    Gilles Gagnon replied 14 years, 5 months ago 3 Members · 6 Replies
  • Angelo Mike
    March 20, 2012 at 8:21 pm
    That’s what I do. How much simpler could it get?
    http://www.scenethroughglass.com
  • Gilles Gagnon
    March 20, 2012 at 8:24 pm
    Perfect!
    Simple enough! I’m sure copying the track only copies references to the source, therefore I’m not increasing disk usage.
    Thanks for the confirmation Angelo
    Gilles
  • Mike Kujbida
    March 21, 2012 at 1:31 am
    [Angelo Mike] “How much simpler could it get?”
    Glad you asked 🙂
    Method #1 (not crazy about this one as it pans the audio hard left and right).
    Options – Prefs – General – Import stereo as dual mono.
    From the Pro 10 readme:
    When this check box is selected, two-channel audio files will be opened as separate mono audio events on separate tracks.
    The audio events are grouped, and tracks that are created by adding media will be panned hard left and hard right. You can select an event and choose Edit > Channels to choose which channel is used for that event.
    You can use this feature when working with two-channel source media that contains two distinct audio channels, such as an interview in which channel 1 contains the interviewer’s voice and channel 2 contains the subject’s voice.
    When the check box is cleared, two-channel audio files will be opened as a stereo pair on a single track.
    Method #2.
    Download and run this script any time you need it.
    This script (courtesy of Edward Troxel) will split a stereo track into two separate tracks.
    https://dl.dropbox.com/u/20488019/StereoSplit.js
  • Gilles Gagnon
    March 21, 2012 at 2:34 am
    Thanks Mike,
    I don’t quite get the diff between copying the track and using L channel on the first and R chan on the 2nd… compared to using the splitting script.
    Can you clarify please?
    thanks! 🙂
    Gilles
  • Mike Kujbida
    March 21, 2012 at 11:08 am
    No difference at all Gilles, just a matter of personal preference.
  • Gilles Gagnon
    March 21, 2012 at 11:11 am
    thanks Mike,
    Gilles
