Splitting audio and video in Vegas 7.0b
Posted by Steve Cheramy on December 9, 2006 at 6:03 amHow do I seperate audio from the video in order to use just the video clip in Vegas 7?
Steve Cheramy replied 19 years, 5 months ago 6 Members · 8 Replies -
Terje A. bergesen
December 9, 2006 at 6:26 amDrop the clip on the time line. Select the audio. Press delete.
Terje A. Bergesen -
Peter Wright
December 9, 2006 at 7:01 amVegas 7 defaults to having video and audio grouped, which I personally like, so deleting one will delete both.
To avoid deleting both, select either and hit “U” to ungroup, then delete as desired.
Alternatively, the clip can first be opened in the Trimmer where you can use Tab to toggle Audio only, Video only or both before dragging or sending to the timeline.
Peter Wright
Perth, Western Oz
http://www.allroundvision.com.au -
Gary Kleiner
December 9, 2006 at 7:32 amIf you’re talking about when you drag the media to the timeline, then drag it while holdong the righht mouse button, then choose video only.
If it’s already on the timeline, turn on Ignore Event Grouping, then delete the audio.
Gary Kleiner
Learn Vegas and DVD Architect
http://www.VegasTrainingAndTools.com
Edward Troxel
December 9, 2006 at 12:42 pm[Peter Wright] “To avoid deleting both, select either and hit “U” to ungroup, then delete as desired.”
A couple other options include briefly turning on Ignore Event Grouping or going to the preferences, editing tab, and unchecking the “Cut, copy, and delete grouped events” option which will return it to the Vegas 6 behavior.
Mike Kujbida
December 9, 2006 at 6:16 pmVegas 7 defaults to having video and audio grouped, which I personally like, so deleting one will delete both.
And if you don’t like this new default, change it by deselecting Cut, copy and delete grouped events in Options – Prefs – Editing. Then it’ll act like it did in Vegas 6, etc.
