Activity Forums Apple Final Cut Pro Legacy Split transitions… I dont care!!
  • Split transitions… I dont care!!
    Posted by Josh Evans on September 26, 2005 at 6:53 am
    Every time I try to delete sections of my sequence, or overwrite or whatever, and there is a transition somewhere in there, it wont let me do it.
    It says the procedure will split one or more transitions. Well what if I dont care about the transitions? Why cant that decision be left to me? At the moment I am having to go in and manually delete all the transitions before retrying what I wanted to do. But is there some way of disabling this annoying thing?
    Nick Meyers replied 20 years, 11 months ago 3 Members · 2 Replies
  • Bret Williams
    September 26, 2005 at 8:12 am
    It only gives that notification if your in point or out point splits a transition. There’s no need to delete all transitoins to perform your edit.
    If you’re deleting, then you are probably trying to execute a ripple delete, and your mark in or mark out splits a transiton. The computer has no way of replicating 3/4 of a transition, or deciding which transition needs to be deleted or adjusted or what.
    Normally, you wouldn’t make the decision to split a transition on a ripple delete, insert edit or overwrite edit. So during normal editing procedure if that box comes up, it’s generally a helpful heads up. Not an annoyance.
    If you’re trying to overwrite a large number of transitions, or delete a large number of transitons, you will not get this error. Only if one of your points intersects the transition.
  • Nick Meyers
    September 28, 2005 at 12:33 am
    everything you say is right, of course,
    but i’m finding this to be rather frustrating at times.
    i think the warning should have the option to proceed, and lose the affected transitions,
    or cancel, so you can remove them manually, or change your in/outs.
    a third and more advanced option could be for fcp to modify the in outs for you, leaving your transitions intact?
    cheers,
    nick
