Activity Forums Adobe Premiere Pro Split screen with irregular
  • Split screen with irregular
    Posted by Robert Such on September 24, 2012 at 4:10 pm
    Could someone point me in the direction of a tutorial on how to make a split screen using irregular shapes, triangles in particular, please? I want to use three time lapse sequences in separate triangular split screen areas.
    In conjunct]ion with the titles tool (using triangle shapes), I can’t figure out if I should use the Luma Key or the Track Matte Key.
    Thanks.
    Robert Such replied 13 years, 11 months ago 2 Members · 5 Replies
  • Ann Bens
    September 24, 2012 at 8:58 pm
    With Track Matte its easy to make.
    Make 2 of the 3 shapes seperately in the titler.
    Track 1 clip
    Track 2 clip with track matte effect set to track 3
    Track 3 mask
    Track 4 clip with track matte effect set to track 5
    Track 5 mask
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Robert Such
    September 24, 2012 at 10:57 pm
    Thanks Ann,
    Any chance you could write out what to do a bit more fully, please? Am not advanced enough to follow that…
    Make 2 of the 3 shapes seperately in the titler. OK.
    Then after that?
    “Track 3 mask”, does that mean the third shape in the titler?
  • Robert Such
    September 25, 2012 at 7:59 am
    Gonna give up on Track Matte. In titler, trying to position a wedge shape is a pain in the a***. The size and position are off. For example, to get a shape to appear in the centre of the video, you have to position the shape in titler off to the left!’
  • Ann Bens
    September 25, 2012 at 10:18 am
    Check the resolution of the shape against the resolution of the sequence: they should be the same.
  • Robert Such
    September 25, 2012 at 9:00 pm
    Thanks Ann. Must be it.
