Activity Forums Apple Final Cut Pro Legacy Split Screen Shot in Multiclip Edit
  • Split Screen Shot in Multiclip Edit
    Posted by Matthew Ellery on January 14, 2010 at 2:25 am
    Hello,
    I produce a lot of concert films, and up until now, I’ve used a rather slow editing method – I’d put each camera angle on a different track above each other, sync them up, and then to edit I’d watch one angle, cut it once it gets boring, watch another angle, cut when that gets boring, etc. It was long, but it worked.
    Now one thing I could easily do in this set up, was make split screen shots (like in Woodstock, etc).
    However, I’ve started using Multiclip editing, and due to all the video being on a single track, I’m unsure of how to go about making split screen shots.
    Has anybody solved this on their own projects?
    Thanks for any help
    Matt
    Matthew Ellery replied 16 years, 8 months ago 2 Members · 2 Replies
  • Josh Aderhold
    January 14, 2010 at 7:33 am
    Split screen as you’d like to see both images at once? Well you’ll have to create two different video tracks. Yea?
    Just duplicate your multiclip, one on track one, one on track two. Then crop, resize or do whatever it takes to get both images to fit on the same screen.
    Yea?
    MacBook Pro
    Intel Core 2 Duo
    2.6GHz
    L2 Cache: 6MB
    4GB Memory
    Bus Speed 800MHz
  • Matthew Ellery
    January 14, 2010 at 9:37 am
    Ahhh, simple. I think I must have been trying to make things too dificult for myself…
    Thanks for the help.
