Activity › Forums › Apple Final Cut Pro Legacy › Split Screen.
Split Screen.
Posted by Ayrods on January 22, 2007 at 10:25 pmHi guys.
I have two footage sequences that I need to parallel-edit on a split screen so that half of the screen shows one footage and the other half shows the other footage (something like in Figgis’ “Timecode”).
Does anyone know how to get the split screen on FCP?
Thanks a lot for ur help.
ABret Williams replied 19 years, 8 months ago 4 Members · 4 Replies -
Dan Riley
January 22, 2007 at 10:41 pmPut one on video track one, and the other on video track two.
Double click on the first clip in video track one.
In the viewer go to the motion tab and adjust the size to what you want.
Double click on the first clip in video track two.
If you want a background other than black, move those two tracks you
presently have to tracks two and three, then put some other source
on track one.Render, (probably but not always).
Dan
Dan Riley
January 22, 2007 at 10:50 pmforgot to mention two things:
1- after you size that first clip on track one, highlight the clip in the timeline
and hit copy (apple-c), you then highlight all the other clips on that track but
not the first one. Now go to edit-paste attributes and you will get a box that
asks you what you want to paste. You select basic motion. What you did was
add that size setting you made to clip one to all the clips you highlighted.
Do the same with track two.2- Instead of doing this on a clip by clip basis, you could nest your
finished full screen sequence (drag the sequence to the viewer) and then edit
the whole thing onto track one, and the other sequence, nested, onto track two.
This means you only have to make the adjustment to the size one time.Dan
John Pale
January 22, 2007 at 10:58 pmif you find doing this cumbersome, you might want to look at this plug in
https://www.digital-heaven.co.uk/fcplugins/dh_box.php
Bret Williams
January 23, 2007 at 7:01 amFor a split screen, crop is going to be more of a friend than scaling. Just put the clips on different tracks and crop and move them to taste.
