Activity Forums Adobe Premiere Pro Split h264 .mov files into smaller chunks
  • Split h264 .mov files into smaller chunks
    Posted by Joshua Guerci on October 4, 2016 at 7:55 pm
    Hey I’m working with h264 .mov files in the Premiere workflow. I’d love to find a simple or ‘dumb’ app that can split large .mov files into smaller >15gb files for easier use with cloud backup storage. Any suggestions would be appreciated!
    http://www.filmless.com
    Aleksey Tarasov replied 9 years, 11 months ago 4 Members · 3 Replies
  • Joe Barta iv
    October 5, 2016 at 12:29 pm
    QuickTime has a trim feature where you can set an in and out point on a file and export that section as a new file, if that helps.
    Joe
    Living the SuiteLife!
    Stuff for editors http://www.cafepress.com/suitelife
    http://www.facebook.com/pages/SuiteLife/1524456414462851?ref=hl
  • Duke Sweden
    October 5, 2016 at 2:02 pm
    You can do the same in Premiere Pro. When you go to export media, when the window opens where you choose your codec and make other tweaks, just position the in and out points under the video (the blue line). Start at zero on the left and move the right cursor to where you want the clip to end. Send to AME and set up the next clip, until you’ve done the entire clip. No need for AME to finish encoding.
  • Aleksey Tarasov
    October 5, 2016 at 2:54 pm
    If you want to split w/o re-encoding, take a look at this video splitter (for Windows)
