Activity Forums Maxon Cinema 4D Split Beam in Particle deflector
  • Split Beam in Particle deflector
    Posted by Mic Pool on January 28, 2007 at 1:05 pm
    How do I get the split beam option in the particle deflector to split the beam 50/50. At the moment it seems to deflect about 10 percent of the particles. As I am designing some quantum optic simulations which require a 50/50 split, it would be really boring if I had to manually animate each particle instead of just switching the beam split function on
    Brian Jones replied 19 years, 8 months ago 2 Members · 3 Replies
  • Brian Jones
    January 28, 2007 at 1:44 pm
    the percentage you are looking at is for elasticity not “percentage of split”. In the manual it says “‘some’ particles will be deflected”. I found if you put in 5 deflectors (not right on top of each other – a bit of space in-between) it looks 50%-ish. be aware that the speed of the particles is important too (not too fast).
    Otherwise Thinking Particles and some Xpresso…
  • Mic Pool
    January 28, 2007 at 3:25 pm
    Thanks, that’s a good work around and has got me back up and running.
    The inability to set a parameter value for spit beam does seem to be an ommission in the program. I can’t really see how the function is that useful without some degree of control.
  • Brian Jones
    January 29, 2007 at 12:17 am
    [micpool] “The inability to set a parameter value for spit beam does seem to be an ommission in the program. I can’t really see how the function is that useful without some degree of control.”
    Well, that’s why we have TP I guess. More work but particle by particle control if you want it.
