Activity Forums Maxon Cinema 4D Spline wrap
  • Spline wrap
    Posted by Ben Black on March 16, 2010 at 11:04 am
    I’m using spline wrap to animate a ribbon spinning around a carousel. For my spline I’m using a modified circle.
    The problem is I want the ribbon to follow the path of the circle continuously throughout the animation but I can’t see how to do this. I used to use Path Deformer which had a much larger offset value but I don’t have this plugin anymore.
    Ben Black
    Adam Trachtenberg replied 16 years, 5 months ago 2 Members · 2 Replies
  • Ben Black
    March 16, 2010 at 11:25 am
    Ignore this. Just downloaded Path Deformer Lite which solves the problem.
    Thanks anyway,
    Ben
  • Adam Trachtenberg
    March 16, 2010 at 2:58 pm
    You can do this with SplineWrap if you want to. The offset % goes as high as you need it to go — you just have to enter the number manually or use the spinner instead of the slider.
