Activity Forums Maxon Cinema 4D spline question
  • spline question
    Posted by Jhm1977 on August 2, 2005 at 5:35 pm
    simple question which i dont seem to be able to sort out?!
    once i have created a spline and want to continue addin point to it….How do i do it???
    It might be very obvious but i cant seem to figure it out…
    thanks
    j.
    Adam Trachtenberg replied 21 years, 1 month ago 3 Members · 2 Replies
  • Brian Jones
    August 2, 2005 at 10:11 pm
    Add points to the end of a spline you were doing before?
    Choose the same spline tool as the spline’s type and control-click to add more points. It might not work on the first try so undo if necessary and try again it always seems to work on the second try. It also usually works if you choose the tool click an empty area in the OM (to deselect everything) then ckick the spline then control-click. It’s a bit odd, maybe I’m missing the real method…
  • Adam Trachtenberg
    August 3, 2005 at 1:16 pm
    [Brian Jones] “Choose the same spline tool as the spline’s type and control-click to add more points. It might not work on the first try so undo if necessary and try again it always seems to work on the second try.”
    It should work on the first try, but you have to be in the move/rotate/scale tools, not selection tools.
