Activity Forums Maxon Cinema 4D Spline path and Camera…jumpy
  • Spline path and Camera…jumpy
    Posted by Jon Herron on September 8, 2006 at 11:35 pm
    I have a camera following a spline path which starts straight and curves downward. Ive smooth all the points but still get jumps. Also the camera seems to speed up and slow down while approaching some points, specifically the first point of the curve downward. Any tips on getting a perfectly smooth traveling camera along a spline path with even speed? is there a way to make the spline in to direct path and none editable with no pionts??
    thanks in advance
    Chompy replied 19 years, 11 months ago 5 Members · 9 Replies
  • 9 Replies
  • Adam Trachtenberg
    September 9, 2006 at 4:07 am
    You can achieve uniform speed by setting your path spline’s intermediate points to … uniform. If it’s still a bumpy ride you might want to use a b-spline instead of a bezier. The shape will change, though, so you’ll have to do some adjusting.
    You can convert the spline to a motion path with the timeline command (spline to position path), but the camera rotation will be lost so that’s probably not an option. You can also bake the animation but it will be very hard to edit after that.
  • Jon Herron
    September 9, 2006 at 7:04 pm
    Adam = awesome!, Thanks so much, just what I was looking for.
  • Chris Smith
    September 10, 2006 at 6:51 am
    You can also give my free cam system a try. Here’s the set, it’s the one called CS_Easycam:
    https://sugarfilmproduction.com/CSTools.zip
  • Brad Goosen
    September 18, 2006 at 1:33 am
    hi chris
    thanks for putting your cs tools up for download. i tried to download the file but it came up with page not found… any ideas?
    thanks
    brad
  • Chris Smith
    September 18, 2006 at 3:01 am
    Sorry, yeah our web guy cleared out all the files by accident . Try it again in a day or two when I put the files back.
  • Chompy
    September 26, 2006 at 1:03 pm
    I’d really love these presets – can anyone else post them for download?
    I reckon Chris is a very busy man and I don’t wish to hassle him.
    cheers
  • Chris Smith
    September 26, 2006 at 11:52 pm
    Sorry, give me a few days and I’ll put them back up.
  • Chris Smith
    September 29, 2006 at 11:30 pm
  • Chompy
    October 10, 2006 at 11:50 am
    I reckon its about time I said thank you!
    here goes…
    THANK YOU!
    very very much
    x
    chompy
