Activity Forums Maxon Cinema 4D Spline objects don’t connect
  • Spline objects don’t connect
    Posted by Eugene Dalarov on November 8, 2010 at 12:05 am
    Hi!
    I have a task to make female symbol in splines and then extude it with extrude nurbs.
    But I can’t work out how to do the middle part of the sign (little circle) connect to the other outer part. Functions/connect don’t connect it in one spline object but rather creates some invisible object that can not be extruded.
    Would be glad to hear solution from you:)
    Eugene Dalarov replied 15 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
