Activity Forums Maxon Cinema 4D Spline-Extrude-Fracture……Spline-Fracture-Extrude
  • Spline-Extrude-Fracture……Spline-Fracture-Extrude
    Posted by Craig Whitaker on September 17, 2012 at 8:33 pm
    Hey everybody,
    Coming up against an odd problem. Bringing in type outlines from AI, dropping them into a Fracture THEN an Extrude is causing letters with holes in them to fill in (see attached) If I use a Text object (no MoText) that problem goes away….however….I have client supplied type that I need to extrude. Any ideas how to get around this? Tried going into an extrude first then fracture, but that’s not working out at all. This seems like 101 type stuff but for some reason, it’s not working as I remember it does.
    Craig
    Craig Whitaker
    Digital Design Director
    Assembly
    161 Leverington Avenue Suite 1002
    Philadelphia, PA 19127
    O: 215-487-2060
    craig@assemblypix.com
    Craig Whitaker replied 13 years, 11 months ago 3 Members · 3 Replies
  • Brian Jones
    September 18, 2012 at 3:14 am
    attached? and why a Fracture?
  • Richard Dunstan
    September 20, 2012 at 9:39 pm
    Just guessing here, but if there is any kind of stroke on the text from AI then you will end up with 2 splines close together make it look wrong when you extrude, so check for strokes and open paths, the only other way would be to have the client provide the font file so then you can use motext.
    and I am guessing that he’s throwing it in a fracture object so he can still use mograph effectors? maybe.
  • Craig Whitaker
    September 24, 2012 at 8:32 pm
    Great, thank you, I’ll check out their AI file now. And yes, it’s to us effectors. Thanks!
    Craig
    Craig Whitaker
    Assembly
    O: 215-487-2060
