Activity › Forums › Maxon Cinema 4D › Spline dynamics priorities issue
  • Spline dynamics priorities issue
    Posted by Chat Schoenfeld on June 14, 2010 at 3:43 am
    Hi all,
    I have a very complex scene with two spline dynamics each one attached to an object. Also another 3 expresso tags which makes other objects align to splines to follow other objects. The issue is that one of the dynamics goes nuts, sometimes works better, most….doesn´t. I assumed it was a problem with priorities. I have some to little knwoledge of priorities, so if you could give me some tips to solve it, i would be greatly apreciated. Cause it has been driving me nuts for the last couple of days.
    Cheers
    Chat.
    Adam Trachtenberg replied 16 years, 3 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    June 14, 2010 at 9:42 pm
    Priorities can be tricky. It’s a matter of setting the tag priority and also left to right and top to bottom. In practice I usually find it takes a lot of experimentation.
    If I was you I’d try to cache as much as possible. Disable whatever you can and cache the wonky spline. Then turn the other parts back on.
