Activity › Forums › Adobe After Effects › spiral 3d
  • Posted by Tudor Applen on August 5, 2008 at 12:48 am
    I want to have Particular spiral its emitter up from the bottom of the frame to the top. I imported a spiral from illustrator and pasted into a 3d solid’s position, then rotated that solid by parenting it to a null, and rotating the null’s X axis to 270. Then I pick-whipped the emitter’s xy position to the solid’s xy position, and the emitter’s z position to the solid’s z position, but of course that’s always zero.
    This is easy for somebody, I know. I keep wondering about the Layer Space Transformation as a solution (in an expression), but I’m too ignorant.
    Thanks for your thought in advance!
    Tudor Applen replied 18 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
