Activity › Forums › Apple Final Cut Pro › Spinning beachball on startup
Posted by Steve Connor on September 18, 2016 at 2:15 pmHi, every time I start FCPX I get about 25 secs of spinning beachball, I’ve tried trashprefs, completely reinstalling and taking out all the plugins. It even does it on a new empty library with nothing in. Any thoughts?
Steve Connor replied 10 years ago 2 Members · 11 Replies -
Jeremy Garchow
September 18, 2016 at 3:48 pmWhat else is hooked up to your machine?
What are the machine specs?
Steve Connor
September 18, 2016 at 3:51 pm2008 8-core MacPro 32gb, Radeon 7950 with Sonnet E4P card and G-RAID Drive. Everything else with FCPX runs as expected, the beachball appeared a month or so ago.
Jeremy Garchow
September 18, 2016 at 3:58 pmMy first suspicion would be a hard drive slow down. What speeds are you getting on your boot drive? Externals?
Have you tested the RAM?
Steve Connor
September 18, 2016 at 4:06 pmYes, I thought that too, RAM tests OK and I have an SSD boot with 250mb read and 170mb write
Jeremy Garchow
September 18, 2016 at 4:46 pmAnd X boot is the only slow down you notice?
You have no other peripherals attached?
Steve Connor
September 18, 2016 at 4:54 pmJust a USB printer and I tried removing that as well. Only FCPX has the issue, everything else is fine.
Jeremy Garchow
September 18, 2016 at 6:33 pmSeems odd.
Have you tried making a new user to see if it goes away?
Steve Connor
September 18, 2016 at 6:57 pmThat’s the one obvious thing I haven’t tried! Will give it a go
Steve Connor
September 19, 2016 at 6:30 pmYep, it doesn’t do it if I log in as a different user! Hopefully a clean install of Sierra will fix it
