Activity › Forums › Adobe After Effects › Spinning a 2D graphic making 3D?
  • Vincent Strader
    October 28, 2010 at 6:32 pm
    I know about the animation effects and presets to the right, but they seem to have put every type of animation in there except the 1 simple horizontal spin like a news bug.
    AE CS4 is what I’m using.
    Message Signature:
    I don’t have any charming or witty things to put in my signature. So as Peter Griffen says, “That’s may mama!”
  • Vincent Strader
    October 28, 2010 at 7:16 pm
    Thanks Mr. LaRonde,
    * Make the graphic to spin into a 3D layer.
    * Animate the rotation along the axis of your choice.
    * Repeat as necessary.
    How do I go about making the graphic to spin in a 3D layer?
    Where do I go to animate the rotation along the axis? I added a 3D layer to the project under the layer section.
    While waiting I was messing around with some other features.
    I tried something else. Adding the lightning effect.
    But when I render out the video I keep getting the black background.
    It’s a PNG file I’m working with that’s been saved in PS with a transparent background.
    This issues is talked about here in this thread:
    https://forums.creativecow.net/thread/202/885166
    For transparency, you want “RGB + Alpha”, is what I Read in another thread here.
    I follow those steps and know where they’re talking about. But all my selections are greyed out. I can’t click on anything to change anything.
    Message Signature:
  • Vincent Strader
    October 28, 2010 at 9:05 pm
    Thanks Mr. LaRonde,
    I understand these constant questions from a noob can be frustrating sometimes.
    So feel free to ignore if you’ve said something that’s the answer and I haven’t picked up on it yet. Sometimes after something has been said I don’t pick up on it till reading it 2 or 3 times 🙂
    But yes, I saved the file as a .png file against a transparent background.
    Transported it into AE. Then allplied the 3D layer to it via the “layer” menu button.
    I see the Z axis red bar on it and the Y axis green bar, but I can’t turn the graphic.
    Message Signature:
  • Vincent Strader
    October 28, 2010 at 10:37 pm
    You rock! Thank you very much!
    Message Signature:
