Activity Forums Maxon Cinema 4D Spin & Change Text
  • Spin & Change Text
    Posted by Keri Mcclain on November 18, 2010 at 3:02 am
    I want to make an animation wherein numbers spin in place and change to letters to spell a word. I have made my text (first in Ai, then imported as outlines), both letters and numbers. What would be the best way to go about this?
    If you need other information, let me know.
    Keri McClain
    Be brave. Be true. Stand. – SK
    Ronny Traufeller replied 15 years, 9 months ago 2 Members · 1 Reply
  • Ronny Traufeller
    November 18, 2010 at 1:01 pm
    mmhh, i would do it like this…
    1.
    first use the extrude nurbs tool witch makes ur Ai splines 3d, be sure u use illustrator 8 files when u export out of AI.
    2.
    I am not shure how experienced you are but then you could keyframe
    the letters the make them spin.
    3.
    to make them change from lettrs to numbers or whatever, i would put them
    in the same place and keyframe the visibility using the display tag.
    btw: if the text is not that special you could use the build in text tool in the same workflow. just keyframe the text parameter. in this case you dont have to do the last step.
    regards
